The car randomly stalls out it could be while I am driving or it could be while sitting at idle, but stalls out try to crank it over cranks but no start. let it sit for ten minutes fires right over. replaced the ignition module and ignition coil recently and mass air flow sensor recently. sometimes I will get out disconnect the fuel line going to the fuel pressure regulator hook it back up and will start back up when I go to give it gas the rpm's drop to zero almost as if the fuel got cut off. any ideas of what it could be?
Apr 29, 2017 at 10:11 PM
