Stalling issue
233,450 MILES • 3.0L • 6 CYL • FWD • MANUAL
JASON POHLSCHNEIDER
First i notice a spark or arching on my distributor. Causing a bogging during acceleration only for a few miles clears up and drives fine . after work i started it up and took off the moment i pushed the clutch in it stalls out now if i start the car and push the gas pedal it will stay running i can take off and drive until i push the clutch in. When i push it in i hear a squealing noise as well the car ran fine up to this point what could it be ? I also have IACV unplugged have for a while now was having spikes in my rpm and i unplugged it ran fine. Is it timing electrical? I would appreciated any feedback.
Jan 18, 2017 at 7:18 AM
HMAC300
  • 48,601 POSTS
plug IAC back in and then clean IAC hole and throttle plate on both sides with choke cleaner. if it continues check fuel pressure with a gauge auto parts rent it. the squealing may be the release bearing for clutch we cannot hear it so have it checked locally. See link.
Jan 18, 2017 at 8:11 AM
JASON POHLSCHNEIDER
Im having it checked out by a mechanic Monday i appreciate the advice the car is my pride and joy i really dislike not knowing what the problem could be I'll give him this advice while going thru the motor Monday thank you again
Jan 19, 2017 at 8:00 AM
