Hi Thomas,
An engine needs three things to start and run. Compression, fuel, and spark.
This sounds like a fuel pump but here is a guide that will walk through the basics of what all could cause this:
https://www.2carpros.com/articles/engine-stalls
Have you tried spraying some starting fluid in the intake just to see if it will fire up for a short second? If so, this will confirm the pump.
Another way, is to hook up a fuel pressure gauge to test for pressure.
Here is another guide that walks through how to do this:
Let me know if you find anything with the pressure. I included the procedure to replace the pump just in case I am correct.
Images (Click to enlarge)
Jun 14, 2019 at 8:03 AM
