After replacing fuel and water pump engine still shutting off
1999 CHEVROLET EXPRESS
163,239 MILES
YCARTER909
I have recently replaced the fuel pump and water pump on my van, but it is still shutting off after running for a period of time. After sitting for awhile it starts back up. I was wondering if it is something electric or a sensor. Please can you help me out.
Jun 14, 2013 at 9:50 AM
Good evening,
I would start by cleaning the throttle body and doing a relearn. Carbon on the throttle plate will cause stalling.
https://www.2carpros.com/articles/stall-at-idle
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
Also, check and see if there are any codes stored.
when it stalls on you and will not start, does the RPM show on the dash while cranking? That will tell me if the crank sensor is working.
Apr 17, 2020 at 9:22 AM
