Stalling after start?
2002 SATURN SL2
170,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
FOOLISHSHAWN
One morning I went to start the car, and it started fine then right after the idle dropped down and then shut off. I started it again and the same thing. I then started it and played with the gas pedal, and I got it to stay running at a high RPM but once I let off the gas pedal it shut off. Now I would do this at a high RPM until the car was warm and shut it off wait a couple minutes start it up and would run fine. That lasted about 1 week then it stopped, and I didn't have any problems for about a month and now it is doing it again but this time I can't get it to run after I warm it up.
Jan 29, 2025 at 7:33 AM
  • 110,240 POSTS
What you described sounds like a failing crankshaft position sensor. When they begin to fail, often they are affected by heat.
It could also be related to fuel pressure, but I would suggest checking the aforementioned sensor. Do me a favor. Take a look through this link and let me know if anything mirrors what you've experienced.
Jan 29, 2025 at 12:16 PM
