Stalling after running?
150,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JMOULDER0915
My car starts runs after a little while it shuts down and won't start back until it has cooled off no lights on cluster panel.
Apr 30, 2025 at 8:59 AM
  • 55,732 POSTS
These can be tough problems to fix, we can start with the easy stuff which will be seeing if the fuel or spark has failed, I would use starting fluid after it stalls to see if that makes a difference and if so, I would replace the fuel pump and relay. If it makes no difference then the engine has lost spark.
This video can help us see which system is failing:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Here is the location of the crankshaft sensor in case there is no spark. You will need to remove the A/C compressor to get at the sensor. Check out the images (below). Please let us know what happens.
May 1, 2025 at 3:18 AM
