Stalling after putting in drive and accelerating
168,970 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
TECBOG5.0
Keeps stalling after putting in gear and taking off. Idles fine.
Jan 20, 2021 at 11:25 AM
Just to clarify the issue, are you able to put it into gear at all or does it stall as soon as you put it in gear? You said it can idle fine so I assume this is there is not issue when in park but as soon as it is put in gear, it stalls.
If so here is a guide that will get us started:
https://www.2carpros.com/articles/stall-at-idle
Also, I attached the testing that we need to perform in order to figure this out. Let us know what questions you have. Thanks
Jan 21, 2021 at 8:06 AM
TECBOG5.0
I can hold the brake and give it gas and seems fine. But as soon as you start to take off it shuts off does it in reverse too just not as much. But yes goes into gear fine and has no check engine light.
Jan 22, 2021 at 3:56 PM
Okay. I suspect this issue is caused by an idle issue in gear. So let's do a couple things. Here are a couple guides that we need to review and start crossing things off the list.
This will get us started on what this issue is:
Then I think we have a vacuum leak as the root cause. So here is a guide that will help us find a vacuum leak:
Lastly I am attaching the process from the manual to figure this out and as you can see the top issue is a vacuum leak so let's start there. If we prove there is no vacuum leak then work through the rest of this list attached below. Thanks
Jan 23, 2021 at 9:22 AM
