Stalling or try to reverse it cuts off?
181,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
LINDA DIXON2
I start the car once I start or try to reverse it cuts off. I have to press the gas to get it back started and actually take off.
Oct 18, 2022 at 2:46 AM
  • 55,710 POSTS
This is common when the throttle bore needs to be serviced. IAC motor needs to be replaced or you have a vacuum leak. here are two guides to help you fix the problem with instructions in the diagrams below to help you with your car:
And this guide, only do this when the engine is cold:
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Can you please shoot a quick video with your phone so I can hear the engine stall? That way I can tell for sure what's going on. You can upload it here with your response.
Oct 18, 2022 at 3:10 AM
LINDA DIXON2
I got the car diagnosed by AutoZone, it was a code P0300.
Oct 18, 2022 at 3:20 AM
  • 55,710 POSTS
Okay, usually when this code is present it will be the fuel pump is going out or you have a MAF sensor that has gone out here is the location of the sensor so you can check it out. also, to check the fuel pressure you can follow this guide:
Fuel Pressure (Key ON Engine OFF) .................... 358-405 kPa (52-59 psi)
Oct 19, 2022 at 4:51 AM
