The car keeps on shaking and vibrating?
134,000 MILES • 1.8L • 4 CYL • AUTOMATIC
KELOPEZ
My car keeps on shaking and vibrating when I’m park and when I slow down my car completely stalls then I have to turn it on and off for it to drive again.
Jan 25, 2024 at 2:16 AM
  • 110,246 POSTS
Is the check engine light staying on when the engine is running? If it is, have you checked for diagnostic trouble codes? If not, that is where I would start.
Here is a link that shows how to check all modules for codes:
Next, when this is happening, do you hear any odd sounds or notice any smoke from the exhaust? Have you checked to make sure there are no engine vacuum leaks? If not, check that as well.
Here is a link that explains how to check:
Also, take a look through this link. You may find it helpful. Note: Since the engine stalls, I don't feel it is an engine mount that is mentioned. However, there is other information that may be beneficial.
https://www.2carpros.com/articles/vibration-noise
Let me know as much as you can.
Jan 25, 2024 at 11:47 AM
