Engine shuts off once it gets warm
250,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DJCROONER
Engine runs great until gets warm then stalls while driving. I suspect crankshaft position sensor is bad or possibly really dirty, due to a previous water pump leak.
My main question is can this sensor be removed without pulling harmonic balancer?
Thanks
Mar 29, 2020 at 11:58 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately no. The balancer has to be removed. Here is a tutorial showing how to remove/replace:
I've attached step-by-step replacement pictures below including the sensor relearn process for your Pontiac below.Hope this helps and thanks for using 2CarPros.
Mar 29, 2020 at 12:25 PM
