Stalling
150,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ZACK H
Stalls and then sometimes runs and stalls again. Extreme missing. Dumping gas.
Checked ignition module, crank module and fuel pressure.
Feb 28, 2018 at 5:41 AM
Good evening.
There is fuel pressure regulator on the fuel rail. there is a vacuum line to the regulator. remove the line and turn the key to the on position. see if any fuel comes out the fitting for the vacuum line.
Feb 28, 2018 at 9:45 AM
HARRY P
  • 2,292 POSTS
Is the service engine light on? If so, get the codes. Being an OBD1 car, you do not need a scanner to get them, just a paper clip. Here is a guide: https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Feb 28, 2018 at 10:33 AM
