charging gauges goes all way down then engine shuts down while driving?
150,000 MILES
OLDSHADETREE001
Car charging gauges goes all way down then engine shuts down while driving. Then it will not restart for about 15 minutes later. It clicks but will not restart until about 15 minutes later.
Nov 16, 2022 at 4:15 AM
  • 55,746 POSTS
This happens when the alternator stops working, but to be sure you can jump start the car and test the alternator by using this guide:
Here is a video that will help you jump start the battery:
https://youtu.be/a9Ycibu9cwY
This guide can help walk you through the steps of the alternator replaced with instructions in the diagrams below to help you with your car:
https://www.2carpros.com/articles/how-to-replace-an-alternator
Nov 16, 2022 at 4:56 AM
OLDSHADETREE001
It starts again after about 15 minutes and then runs okay.
Nov 16, 2022 at 5:00 AM
  • 55,746 POSTS
When it is running does the alternator check out okay? The battery can sit and regain surface voltage but then it drains quickly. Let me know please.
Nov 17, 2022 at 6:19 AM
