Van started stalling
170,000 MILES • 5.2L • 2WD • AUTOMATIC
JASON CARR WRIGHT
Suggested that it was fuel pump or ECM. Opted for fuel pump. Still stalling. Replaced pickup coil rotor button and ignition coil. Still stalling. Is there a for sure test for the ECM or should I just assume it is malfunctioning?
Nov 2, 2020 at 2:00 AM
CARADIODOC
  • 34,414 POSTS
Under what conditions does this occur? Does it happen at highway speed, slow speeds, or just when coming to a stop? Any history that led up to this? What does it take to get the engine restarted? Have you checked for loss of spark when the problem occurs? If you have not, here's a kink to an article that may be of help:
Nov 2, 2020 at 9:02 AM
