Intermittent stalling
1,700,000 MILES • 6 CYL • 2WD • AUTOMATIC
LINDALOUMASSENGILL
When I drive the car somewhere park and turn it off and suddenly decide I need to go leave right away and start the car back it will start but it knocks off. I have to wait 30 minutes or so before it will start. It doesn't do it all the time but at least once a week.
Oct 19, 2020 at 2:58 AM
  • 110,248 POSTS
That could be a few things. The idea that it happens when the engine is warm leads me to believe it could be related to the crankshaft position sensor. Take a look at this link and let me know if it mirrors what you experience:
The best way to confirm is to either check for ignition spark when it won't start or check for an RPM signal when it won't start. To check for an RPM signal requires a live data scan tool. However, here is a link that shows how to check for spark without a scanner:
If you find no spark, then I would replace the sensor. Here is a link that shows how to in general:
Here are the directions specific to your vehicle:
_______________________________________________
2003 Ford Truck Escape 2WD V6-181 3.0L DOHC VIN 1 Duratec
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Procedures
PROCEDURES
REMOVAL
1. Raise and support the vehicle.
pic 1
2. Remove the bolts and the right front lower splash shield.
pic 2
3. Remove the Crankshaft Position (CKP) sensor.
1 Disconnect the electrical connector.
2 Remove the bolt.
3 Remove the sensor.
INSTALLATION
1. To install, reverse the removal procedure.
________________________________________________
If you find this isn't the issue, check the PCM relay and fuel pump relay under the hood in the fuse box. One at a time, simply switch them with another relay that has the same part number and see if that makes a difference. See pic 3.
Oct 19, 2020 at 7:19 AM
LINDALOUMASSENGILL
Thanks, I was thinking crank shaft sensor.
Oct 19, 2020 at 9:32 AM
  • 110,248 POSTS
You are very welcome. If you have a chance, please let me know if this takes care of the problem.
Oct 19, 2020 at 1:30 PM
