Stalled while driving and when transmission is put into drive
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
MITZI GIBBS-HARTMAN
  • 36 POSTS
I was driving the car and it stalled put it in park started it up and started up fine put it in drive stalled again. I just bought this car and it may have sat for a little while, do you think the fuel may have gone bad? Does it has something to do with it? I had it towed home.
Jun 1, 2018 at 3:08 AM
  • 55,743 POSTS
Hello.
When you put it in the does the car jolt like a standard transmission car you just let the clutch out? Can you take a quick video of what the car is doing so I can see and tell for sure? You can upload it in your reply.
Is the check engine light on? If so lets run this guide.
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Cheers, Ken
Jun 2, 2018 at 6:56 AM
