Stalling when stopped
23 MILES
NANCY DECICCI
Car stalls at stop sign will restart but will only stay running if giving it gas. meter reading at auto store said cam shift position sensor. I changed both and crank shaft position sensor. still doing the same thing.
Mar 30, 2019 at 7:21 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Have you checked for engine vacuum leaks? That can cause a stalling problem along with a dirty throttle plate. Here are a couple links to check or service those things:
Let me know if that helps.
Mar 29, 2021 at 3:03 AM
