Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Symptoms
Stall While Driving
Engine shuts off while driving
1994 TOYOTA CAMRY
160,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MITZI GIBBS-HARTMAN
MEMBER
Well, driving about 25 miles an hour the car just stalled. It will start but it will not stay started.
Oct 22, 2018 at 4:00 AM
Experienced Mechanic
Good afternoon.
You need to find out if it has lost spark or fuel.
A fuel pressure test and spark test need to be done to verify.
Also, it could also be a timing belt that may have jumped from age or a failed tension-er. a compression test will verify this.
https://www.2carpros.com/articles/how-a-timing-belt-works
Oct 22, 2018 at 5:34 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
