Stalling while in idle and at intersections?
244,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
HERE IN MY CAR
Had heads replaced. Stalling while in idle and at lighted intersections place in park starts right up. (No check engine light at all)
Replaced, crank sensor, cam sensor, throttle body (and its connection on wiring harness) MAF sensor, MAP sensor, oil pressure sensor, and coolant temperature sensor...
Still stalling! No check engine light, still running on oil shop put in after repairs. Not synthetic (What I've always used in car since I've had it)
Suggestions much appreciated!!
Jan 4, 2023 at 4:35 PM
  • 55,604 POSTS
It sounds like you have a vacuum leak, or the air intake tube is loose or cracked. here is a guide to help is fix it, please follow this guide when the engine is cold only:
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Can you please shoot a quick video with your phone so I can see the engine run and stall? That way I can tell for sure what's going on. You can upload it here with your response.
Jan 5, 2023 at 3:49 AM
