Stalls when accelerating?
108,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JCKEIFER
Start and Idles fine stall when giving it gas.
Will idle drive, but as soon as I try to get to a normal speed it stalls.
No check engine light on.
I am thinking fuel filter or fuel pump.
May 6, 2021 at 2:50 AM
This could be a fuel issue but it also could be a vacuum leak. So we need to check both.
here are guides that will show you how to do these tests:
Let's run through both of these and go from there. Let us know what you find. Thanks
May 7, 2021 at 12:31 PM
