car stalls but not on a regular basis
140,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
RANDYDUNN10
  • 29 POSTS
The car stalls but not on a regular basis. Car runs good. Plenty of power. Does have slight rough idle. Any ideas?
Jun 17, 2019 at 8:08 AM
There are a couple issues that can cause this to happen but it could be related to the rough idle, so we need to start with this and make sure it is not related.
Here are a few guides that will help with this. I suspect we have a vacuum leak or a misfire. So, we need to check for both of these.
https://www.2carpros.com/articles/stall-at-idle
If we resolve the rough idle and there is still a stall, then we need to suspect the crankshaft position sensor.
I am attaching the process on how to replace it as this was a common issue on these vehicles so I would suggest just changing it and retesting it due to it being so common.
Please run through this info and let us know what you find. Thanks
Oct 28, 2021 at 10:51 AM
