Engine shuts off when transmission is shifted into drive or reverse
194,455 MILES • 4.5L • V8 • 2WD • AUTOMATIC
STEVEN GILL
Car is hard to start. But then idles fine once it warms up. Shuts off when it is put in drive or rev.
Feb 18, 2020 at 6:06 AM
Good evening,
The first thing I would do is check the fuel pressure. It would explain both issues.
You can rent a tester at a parts store.
There is a motor on the throttle body that can cause the stalling going into gear. That could be the reason for this.
Feb 18, 2020 at 8:07 AM
