stalling
110,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHRIS KOLB
I got into my car after twelve hour shift. When I put the car into reverse the car stalled. The battery light and oil light came on as soon as it stalled. I stared it back up and everything was fine.
Later when it did the same thing. I started it back up and worked fine. is this a big problem or?
May 16, 2016 at 10:44 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate and iac hole on both cars see if that takes care of it
May 17, 2016 at 1:08 AM
  • 55,781 POSTS
Hey Chris,
Here is a guide on how to do the cleaning
http://youtu.be/rNQGEGvophg
Also check for vacuum leaks which can also cause the engine to stall
http://youtu.be/xN5pcM-5bso
Let us know who it goes
Best, Ken
May 17, 2016 at 9:49 AM
