Stalling
RON7769
  • 1991 CHEVROLET S-10
  • 172,089 MILES
I have replaced map tps ignition module injectors and checked iac operation. As long as the vac line is off the truck will start and kind of run as soon as I hook it up it stops running. Why is this?
Saturday, May 11th, 2013 AT 1:47 PM
  • 52,797 POSTS
I will generalize since you provided no engine size
could be a vacuum leak under the throttle body, iac motor, how did you check it?
Is the check engine light on?
Tuesday, August 21st, 2018 AT 3:27 PM
