Stalled going uphill now will not start
61,142 MILES • 3.0L • V6 • 4WD • MANUAL
LORDTAYLOR97
I was leaving my house everything started fine. When I turned left to go up a hill, my rear end lost traction and started to slide out but before I could get it back under control the engine died and now won't start.
Oct 26, 2021 at 7:46 AM
  • 110,248 POSTS
Is the starter engaging to crank the engine? If it is, we need to start by checking for spark and fuel to the engine.
To get started, take a look through this link. It discusses the most common causes of a crank no start. See if it helps.
Next, I need you to try a little trick. See if the engine starts for a couple of seconds and stalls if you use starting fluid. If it does, then it is a fuel-related issue. If it doesn't, then it's likely ignition related.
To confirm if it is an ignition issue, follow this link:
Oct 26, 2021 at 12:35 PM
