ran car thru large puddle stalled now when hit key car just clicks once starter doesnt crank
Apr 17, 2013 at 11:53 AM
✓Experienced Mechanic
sounds like the motor is full of water.
have a shop check it for you to confirm
Apr 17, 2013 at 12:07 PM
SYNERGYTECH
MEMBER
Mine did that ,fuses no 38 and 45 ,those plastic fuses that plug in like relays under the hood ,the manual tied them in to crank and run.one checked good but actually wasn't , there around 5 bucks each at autozone.Hope this helps. You might check them all while you're at it.
