Stalls while driving
78,000 MILES • MANUAL
KRISTI WILSON
Twice now my car has stalled when driving. The battery and engine light comes on when this happens. I can restart my car no problem and continue driving. It seems to be happening when I'm down shifting turning a corner. When I reduce my speed shift into third gear from fourth I notice the rpm's drop drastically. Car seems fine otherwise.
Oct 3, 2019 at 12:17 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Does it seem as though the idle is just too low? I have to be honest, this could be several different things. First, if the check engine light is on, have the computer scanned for diagnostic trouble codes. Most parts stores will do it for free. Let me know if any are found.
If the light isn't on, check for engine vacuum leaks. Here is a link that shows how that is done:
Next, if nothing is found, it could be related to a dirty throttle body or even an Idle air control module (IAC). The IAC is responsible for idle speed. Here is a link showing how to clean a throttle body:
Here is a link showing how an IAC is serviced:
https://www.2carpros.com/articles/idle-air-control-valve-service
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Start with these things and let me know if anything here helps.
Also, I can provide specific info, but I need the engine size.
Oct 3, 2019 at 11:27 AM
