Stalling at idle?
80,000 MILES • 2WD • AUTOMATIC
KWIEGAND
  • 5 POSTS
Noticed car would rumble a bit while idling like it was about to stall but didn’t. Escalated to stalling on idle while waiting in car line or at a red light. Starts right back up. Then a low oil pressure warning flashed, and engine light came on and I took it to repair shop. They ran a diagnostic and said I need a $1,900 time up.
Oct 18, 2023 at 7:06 AM
  • 110,248 POSTS
At 80,000 miles, there is nothing as far as a tune-up that would cost nearly that amount of money. Actually, if it has 180K there is nothing that would cost that amount. At this point, don't have it done.
A rough idle or stalling is usually the result of an engine vacuum leak, a fuel pressure related issue, an idle air control valve (IAC), and so on. None of this would cost that amount of money.
Take a look at this link:
https://www.2carpros.com/articles/stall-at-idle
If you have your vehicle, safely drive it to a nationally recognized parts store and have them scan the computer for diagnostic trouble codes. Record what they find and let me know the codes.
Also, in the interim, check for possible vacuum leaks.
Here is a link that explains how to check:
If by chance they wrote the diagnostic codes down for you, let me know what they are.
Oct 18, 2023 at 11:53 AM
KWIEGAND
  • 5 POSTS
I will go to the mechanic today and get a copy of the report.
Oct 18, 2023 at 8:56 PM
KWIEGAND
  • 5 POSTS
P2195 - B’s’ stuck lean
P2197-B2s stuck lean
B1 O2 sensor $292
B2 O2 sensor $226
Labor $132
Also said I need new spark plugs $92
Coil packs $814
Labor $253
Oct 18, 2023 at 10:31 PM
  • 110,248 POSTS
What size engine is in the vehicle? Is it a 4-cylinder or 6-cylinder? I ask because coil packs are usually under 50.00 each.
As far as the oxygen sensors are concerned, they too are not expensive.
Is this something you would feel comfortable doing yourself? I feel you could do this all for under 500.00. If it is a 4-cylinder, it will be less.
Also, I just want to point out that if the O2 sensors are stuck leak, that is causing the computer to add too much fuel. Chances are the coils and spark plugs don't need to be replaced. I say that because in my mind, I suspect either you have an engine vacuum leak, a weak fuel pump, or it is the O2 sensors. Also, are there any exhaust leaks that you are aware of?
Let me know. If I can help, I would like to.
Oct 19, 2023 at 10:17 AM
KWIEGAND
  • 5 POSTS
I called a couple other shops, and they all quoted me around the same price to do the sensors. We decided to go ahead with the sensors and the other stuff we are going to try and do ourselves. We just need the immediate problem fixed to get the car back as soon as possible.
I really appreciate this service you offer here, and I would like to contribute if you have a way of accepting money.
Oct 19, 2023 at 11:07 AM
  • 110,248 POSTS
Thanks for the update. As far as the oxygen sensors are concerned, if they are truly bad, that could resolve all the issues. If you have a chance, let me know how things turn out for you. I'm interested in knowing.
Also, there is no need to contribute. We appreciate the offer. The only thing I can tell you is they have a GoFundMe page.
Here is the link, but please don't feel obligated:
https://www.gofundme.com/f/help-us-help-others-get-back-on-the-road
Let me know how things work out for you. If we find it does need spark plugs or coils, we will cross that bridge when we get to it. You're not alone. I'll walk you through how to check things.
Take care of yourself,
Oct 19, 2023 at 12:45 PM
KWIEGAND
  • 5 POSTS
So, I got my car back and took my daughter to school today and I noticed when I was stopped at a long light, holding my foot on the brake, that the car started running rough again. When I got home, I sat in the driveway with my foot on the brake, and after about two minutes of idling, my car started puttering like it was going to stall, but it never did. I then switched to Park and it’s been five minutes and it’s idling just fine. Could having a vacuum leak in my brakes cause my car to run rough somehow?
Oct 22, 2023 at 10:25 PM
  • 55,746 POSTS
Yes, chances are the oxygen sensors were not bad, these codes come up when the engine is getting too much air which can be caused by a vacuum leak. With the engine off, remove the vacuum check valve from the brake booster and you should hear air escaping. Here is the location of the valve. Also, here is a guide that you should use when the engine is cold:
If you don't hear air escaping the booster is bad, here is how to replace it. Check out the images (below). Please let us know what happens.
Oct 23, 2023 at 5:22 AM
