I will be as detailed as i can. I am fairly mechanically inclined, but this one has me pretty stumped.
Okay, in a nut shell, it will start up and idle great. Then i drive it, less than a quarter mile it will shut off. when it shuts off, 1 out of 10 times it will fire right back up and i drive home. the other times it will not start.
Here is the thing, its not hot or over heating, but it will start back up if i let it sit for a hour or two.
I have a noid tester, and i can tell you when it is in this weird "hold" state, the injectors have no power. But like i said eventually something changes and eventually they come back online.
I originally thought it was the camshaft sensor (i have the type in the distributor) so i went ahead and replaced the whole distributor. same symptoms. I have also replaced the fuel pump and ECCS relays, i have three different ECM's and no matter which i use, it still does the same thing.
To me, it feels like something with the authority to turn off the injectors is panicking and shutting everything down,. then after a complete random amount of time, it resolves itself and i can start it again.
keep in mind, i can let it idle in the drive for hours and it never shuts off.
Help, looking for suggestions. I also, do not have a ODB port. it is one year too old.
Jun 19, 2019 at 5:06 AM
