Staggered wheels vs standard
30,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
JAMAL BOWIE
I would like to know can you switch out oem 20" tire wheel package staggered for standard size all four the same size tire wheel package?
Nov 8, 2018 at 5:03 AM
JONNYB1963
  • 263 POSTS
Hi Jamal,
You can change the tires and rims on the car provided that the rims have the correct offset and the tire diameter is correct for the wheel well clearance. The stock rim sizes on Camaro's of this year are 18, 19, 20 and 21 inch (depending on the trim package you have, LT, RS, SS or ZL1). I am not certain what you meant by "staggered" but I suspect that you really meant offset. Am I right about that? Make sure that the rims are offset the same as the factory rims, if not, they might rub. Also the handling of the car will suffer if the offset is not standard.
Hope that helps,
Jon
Nov 8, 2018 at 9:44 AM
