StableTrek needs servicing?
125,000 MILES
CAM61
  • 5 POSTS
This popped up in message center “reduce engine power”. Now the car won’t start and when I put a code reader on it all kinds of codes were popping up.
Jul 10, 2023 at 8:28 AM
  • 110,251 POSTS
What codes are present? As far as the stability control, that won't prevent it from starting, so something different is happening. I need to see the codes.
Also, is the ABS light on also? I ask because the two, ABS and Stability control, are commonly associated due to a failed wheel speed sensor.
Jul 10, 2023 at 3:42 PM
