stabilitrak light is on and sometimes it is hard to get it to go into gear
110,000 MILES • V6 • 4WD • AUTOMATIC
KIMLERK
I have to press on the brake a few times then it will go into drive or reverse.
Feb 21, 2021 at 6:50 AM
We need to start with checking for codes. Normally these items, stability track and the brake pedal, are not related but there could be a link which is why we need to start with codes.
Here is a video as well that does a good job of explaining traction control just in case you want to get some more info.
https://youtu.be/K5AJVMk4U8Q
However, we need to start with codes and go from there. Thanks
Feb 22, 2021 at 10:47 AM
