Stabilizer link replacement cost
80,000 MILES • 4 CYL • 2WD • MANUAL
BTROTT
Hi guys. Just looking for some advice as I'm looking to purchase the vehicle listed above. The seller has told me the stabilizer link on the front right wheel needs to be replaced and the vehicle was purchased with this issue. Apparently caused by the larger diameter rims on the car.
I've done a little bit of research on this and it seems as though the part is quite cheap. But that's as far as I've gone.
When driving, it drives really well but there is a slight knock sort of sound going over certain bumps.
Just wondering how bad can this problem get as they said they've been driving with it for a while? And how much would it generally be to fix?
May 19, 2020 at 7:43 PM
BMDOUBLE
  • 1,139 POSTS
If they are selling it with the same issue that they purchased it with, then I usually walk away from that deal because the small issue might be a large one like frame/body damage from a collision, or something more complex that is not easily or cheaply fixed. That's my opinion though. Senior master Ford technician, 27 years experience, Houston region tech representative Ford technician review panel alumni.
May 20, 2020 at 3:36 AM
