Stability traction control light was on?
180,000 MILES • V8 • 4WD • AUTOMATIC
BECBIRD24
Stability traction control light was on, it went out and service engine light started flashing. when i start and stop it shifts hard like slipping and has a ticking noise.
Oct 17, 2022 at 12:04 AM
  • 55,628 POSTS
These might be two different problems but let's fix the warning light to see if that fixes the problem. The traction control light usually comes on when there is a wheel bearing hub going out because the wheel speed sensor is built into it. It is probably one of the front hubs. here is a video that shows how to change them out but to be sure let's run the codes (CAN SCAN) to see what comes up. You can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner link for about $35.00:
https://amzn.to/3R9lJ60
Here is a guide and video that show how to do the bearing hubs just in case you need it:
https://www.2carpros.com/articles/bearing-hub-replacement
and
https://youtu.be/ZgiPRG6jffc
Please go over these guides and report back.
Oct 17, 2022 at 3:30 AM
