Stability control light on?
220,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MARVINJOHNSON9
After starting the vehicle in the morning, the traction control light/stability light came on. Pushing the stability control button hasn't changed this issue.
Apr 3, 2023 at 11:43 PM
  • 55,676 POSTS
It sounds like you have a wheel bearing hub that is out which houses the ABS wheel speed sensor, which can cause the light to go on when it doesn't read correctly. But to be sure let's run the codes to see what comes up.
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Here is a video of how the job is done in case you need it:
https://youtu.be/ZgiPRG6jffc
Please go over these guides and report back.
Apr 4, 2023 at 3:32 AM
