stabilitrax and traction control service lights with check engine light flashing
5.3L • V8 • 4WD • AUTOMATIC
MIMITHEQUEEN
I have a 2007 GMC Yukon XL...I was driving down the highway and heard what sounded like a spring being sprung....then there was a thumping..the traction control and stabilizer service lights came on with the check engine light flashing....I got off the highway...It was a hard acceleration with some clunks but once moving the vehicle was fine...I had no loss of power, no missing, no overheating, no lose of mileage...I drove it to the mechanic who said I need a new engine...that is was only running on 7 cylinders and that was causing an imbalance making the stabilizer and traction control lights to come on and it needed a new engine...is this possible?
Feb 15, 2014 at 2:48 AM
CARADIODOC
  • 34,406 POSTS
That's a hard one to swallow without actually seeing it or any test results. I think it's time for a second opinion. A misfiring engine will have a very noticeable feel at idle. Since the Check Engine light turned on, we know the Engine Computer detected a problem and set a diagnostic fault code. Knowing the exact code number can help in determining a plan of diagnosis.
Feb 15, 2014 at 6:31 AM
