Stabilitrak and traction control
230,000 MILES • 5.8L • 6 CYL • RWD • AUTOMATIC
TERRY DEFOE
  • 5 POSTS
When I start my van it says service stability and traction control. Gear shifter will not show what gear I am in on dash and while driving it will not change gears.
Sep 23, 2017 at 10:22 AM
STEVE W.
  • 15,370 POSTS
You need a shop to scan the ABS/Stability Control system. That will at least give some direction to what the problem is. Do not bother with the "free" scans at parts stores those only scan the engine/emissions systems. You need a better scan tool to access the system that you are having an issue with.
It could be as simple as a blown fuse or a bad speed sensor or wheel speed sensor. The information from the scan will help.
Sep 23, 2017 at 4:59 PM
