Stabilitrac
78,000 MILES
STRAUGH
When starting out or operating at lower speed my Escalade's stable-track activates almost every time. Is this a sensor or a hub problem? Can I get the codes for both. Dealership says it's one or the other, but the difference is about $450 just for parts. Any help?
Mar 1, 2016 at 8:07 AM
HMAC300
  • 48,601 POSTS
This has to be scanned by a professional grade scanner, but you don't need a dealer for that. It can be like dealer says, but the sensor may be in the hub so have it scanned first. In the meantime look for a bad ABS wire as they are very thin and likely out of position etc.
Mar 1, 2016 at 11:24 PM
