SRT8 randomly shutting down
120,000 MILES • 6.1L • V8 • AWD • AUTOMATIC
STEVEN JAMES BREWER
While driving my friends vehicle under forty, it will randomly shut off. The harness has been ohm, 2 PCM's replaced a TCM, cam, crank, map, TPS, throttle body, o2, and pretty much every other sensor you can think of has been replaced. I want to check the fuel pump for intermittent operation but my buddy is (absolutely) sure that is not the problem. I want to ask simply because now he is looking to replace the front control module and entire wiring harness which we all know is mind blowing expensive, especially if it does not fix the problem. Can anyone help me? Oh and it was at a certified mechanics shop for five months.
Apr 8, 2017 at 12:16 AM
HMAC300
  • 48,601 POSTS
if you can hook up a fuel pressure gauge and drive it see what it is. should be 59psi +-5 psi. it may be the tpim module messing up on this vehicle. there is a recall on some models for an ignition switch as it can cause vehicle to quit running suddenly. call dealer with VIN number see if it is involved. number is RC-P41-15.
Apr 8, 2017 at 12:43 AM
