SRS light stays on all the time
181,900 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
EDIN OSMIC
SRS light stays on all the time, I got code 51 says in book motor lock ? What motor lock and where is located ? Thank you
Nov 24, 2017 at 10:04 AM
HARRY P
  • 2,292 POSTS
Code 5-1 (or 51) indicates an internal failure in the SRS unit. Most likely, it needs to be replaced.
Check out the answers to this same question in an older post: https://www.2carpros.com/questions/honda-odyssey-1996-honda-odyssey-srs-light
In particular, look at the second answer.
Good luck and let us know if you need anything else. We are here to help.
Nov 24, 2017 at 11:20 AM
