I just came from watching your video on YouTube (https://youtu.be/gnSGfEqrf_w) for clearing the airbag trouble code. Unfortunately the OBD scanner you recommend is no longer available on Amazon. Is there another scanner you could recommend that I can use to clear the airbag trouble code on my car listed above? In case it's relevant, the light came on shortly after I installed a new stereo in the car. While doing that I made the mistake of disconnecting the passenger passenger airbag indicator light.
Jul 11, 2019 at 3:16 AM
