SRS light is on, how do I reset it?
223,000 MILES • 6 CYL • 4WD • AUTOMATIC
INDHIANTY
Airbag SRS light is on how to reset it.
Jun 21, 2022 at 9:47 AM
SQM
  • 6,383 POSTS
The airbag light will get illuminated when the on-board diagnostics detects any faults within the airbag system.
It could be any number of components, like faulty crush sensor, airbag module, wiring issue etc.
First you want to make sure the issue is taken care of then you will be able to reset the light.
In order to do that you will need a scanner that is capable of retrieving airbag error codes.
Here is one of our helpful videos that shows how to retrieve and clear airbag codes:
https://youtu.be/gnSGfEqrf_w
Let me know of any questions.
Jun 21, 2022 at 1:13 PM
CARADIODOC
  • 34,414 POSTS
The goal is not to "reset" anything, at least not yet. The Air Bag Computer has detected a defect in the system. When it does, it sets a very specific diagnostic fault code, turns the system off, and turns on the warning light to tell you. On some models disconnecting the negative battery cable for a minute will erase fault codes, but very often that doesn't work for Air Bag and Anti-Lock Brake Computers. Those may need a scanner to manually erase the codes.
Often these defects are intermittent and may not reoccur for a while. Knowing the code number gives us an idea of what might be happening.
The place to start is by having the fault code read and recorded. The people at many auto parts stores can do that for you for free, but quite often they can only read codes in the Engine Computer. It depends on how new the equipment is they're using.
Once you know the exact code number, you can pursue erasing it, then drive the car to see if it comes back. If it does not, a good suspect is something related to the air bag system was unplugged while the ignition switch was in "run".
Another good suspect is a broken clock spring. That's a wound-up ribbon cable in a plastic housing under the steering wheel. The fault code will refer to an open "squib", or open "initiator" circuit. When the ribbon cable breaks, at some point other functions with switches on the steering wheel will also stop working. Most commonly that's the horn and cruise control.
Here's links to some related articles you might find helpful:
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Let me know what you come up with for the fault code and I'll look up the definition and diagnostic steps for you.
Jun 21, 2022 at 1:29 PM
