Hi HeyJude12333,
You need to remove the meter cluster to replace the bulb.
GAUGE ASSEMBLY
Removal & Installation
Remove gauge assembly trim panel.
Remove 4 screws from gauge assembly. Place protective cloth over upper steering column. Partially pull out gauge assembly. Disconnect gauge assembly connectors. See Fig. 6 . Remove gauge assembly. To install, reverse removal procedure.
![https://www.2carpros.com/forum/automotive_pictures/192750_Meter01MDX_1.jpg](https://www.2carpros.com/forum/automotive_pictures/192750_Meter01MDX_1.jpg)
GAUGE ASSEMBLY TRIM PANEL
Tilt steering column down. Remove 2 gauge assembly trim panel screws. Gently pull out along edge of gauge assembly trim panel to release 4 retainer clips. Disconnect electrical connectors and remove gauge assembly trim panel. To install, reverse removal procedure.
SPONSORED LINKS
Monday, October 27th, 2008 AT 3:48 AM
