SRS light disable
200,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BROKENEGGS
  • 198 POSTS
Is there anyway to permanently disable the SRS light?
Sep 29, 2018 at 1:59 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
That means a code is stored related to the SRS system. Have you checked the code(s) to see what problem is indicated? Just curious why you want to disable? You can take the mini-bulb out of the socket in the instrument cluster if you like. I have attached a tutorial on how to check codes. If you do not have access to a code reader your local auto parts stores can scan for free. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 29, 2018 at 9:40 AM
BROKENEGGS
  • 198 POSTS
This is a lot of good information Danny. Thanks very much.
Sep 30, 2018 at 12:02 AM
BROKENEGGS
  • 198 POSTS
The reason I wanted to disable the light was that I thought I would not be able to pass inspection here in Texas since I did not know how to fix the problem. But to my surprise after checking with an inspector I found out that the SRS light being on has no effect on a inspection in Texas.
Sep 30, 2018 at 12:09 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks again for using 2CarPros.
Danny-
Sep 30, 2018 at 8:54 AM
BROKENEGGS
  • 198 POSTS
Thank you!
Sep 30, 2018 at 10:22 PM
