SRS light on
83,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RICHARD756
srs code r 1 2/9 driver side air bag squd is too high.
May 5, 2021 at 10:52 PM
  • 110,251 POSTS
The resistance is too high. Chances are it is related to a broken/faulty clock spring in the steering column.
Also, just fyi, there was a recall on the airbags on many of these vehicles. Have you had them replaced or determined if this vehicle was affected?
The clock spring is located in the steering column. What I recommend is having the can-bus system scanned for codes. CAN stands for controller area network. Basically, all the computers/modules are tied together via a few wires. By performing this type of scan, we will know if any other codes are present.
I'm suggesting this because there are other things that can cause the code. A faulty squib connection, an open circuit between the module and airbag,
Here is a video showing how the can is scanned:
https://youtu.be/InIlnsjOVFA
Also, I attached the schematics for the supplemental restraining system. I had to cut it in half to make it readable, but I did overlap them so you can follow from one to the other.
I highlighted the airbag squibs. Note that they both go through the clock spring to the steering column module. From there, they go to the restraining module. My first thought is the clock spring.
I hope this helps. Let me know if you have other questions.
May 7, 2021 at 1:05 PM
