Sqweaking noise from around belt area
95,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
MJDT45
I hear the noise while in gear while stopped. The noise susides while in the
Parked position. All fluids are up. Thanks
Oct 28, 2015 at 5:17 AM
  • 31,937 POSTS
belt may be worn or cracked, you can run the engine with out the serpentine belt for a bit to see if the noise goes with it off, also just make sure all pulleys are noise free with the belt off spin them they should turn freely and with out any noise.
Oct 28, 2015 at 6:33 AM
  • 31,937 POSTS
I will just add, do not drive the car with the belt off, just run for 10-15 sec just to confirm if noise is still present or not.
Oct 28, 2015 at 6:34 AM
