Squealing under hood when starting the engine. It lasts ten to fifteen seconds.
Oct 14, 2017 at 10:12 PM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
make sure the accessory drive belt or belts are tight. If it is a single serpentine belt, remove it and if the noise goes away, then it was the belt, and if so, it is probably a weak tension-er, so replace it. If it is a V-belt, try tightening it if it is loose.
Oct 15, 2017 at 1:13 AM
yes i agree, check drive belt tensions and adjustments, also check for contamination on belts like grease and oil leaks.
