Squealing sound
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
JENANN4
Hi
When I start up my car for the first time it gives off a loud squealing sound. It goes away soon and rarely does it again when the engine is warm.
Thank you
Jen
Sep 4, 2025 at 7:25 AM
MECHTRIX
  • 573 POSTS
Super comon ..You might have a loose or warn out belt that just needs adjustment but if its dry cracked or the like just replace it theyre pretty cheap and last a few years
Good luck hope this helps
Sep 4, 2025 at 9:13 AM
  • 55,616 POSTS
Can you please upload a short video of the noise so we can hear it to be sure?
Sep 5, 2025 at 1:01 AM
JENANN4
We replaced both belts
Sep 5, 2025 at 12:14 PM
JENANN4
I will have to figure out how to send the noise
Sep 5, 2025 at 12:15 PM
  • 55,616 POSTS
If the belts are loose even if they are new they will squeal. You can take a short video with your phone and upload them in your repones here, with the engine off check the tension of the belts (engine cold) they should be like a guitar low E string.
Sep 6, 2025 at 3:39 AM
