Squealing noise coming from front right wheel while driving
75,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
AMA
Most noticeable at low speeds. I already replaced brake pads, rotor, wheel hub and bearing and front shock. The noise drives me crazy. I made a video of the noise here:
https://m.youtube.com/watch?v=CUrSSYERn1U&feature=youtu.be
Any ideas what’s causing that? I appreciate your help. Thank you.
Oct 23, 2019 at 2:10 PM
SCGRANTURISMO
  • 4,897 POSTS
When did the squealing first start? Did it start before or after the new brakes were installed? It sounds almost like the squealer that tells you when the brakes are low has been installed on the wrong side of the caliper. Please get back to us and let us know and we can go from there.
Thanks,
Alex
2CarPros
Oct 23, 2019 at 4:57 PM
AMA
Thank you a bunch for your response. We changed parts in this order:
- Struts
- Brakes and rotor
- Wheel hub and bearing
All the parts were changed within past three months. The reason we changed wheel hub and bearing is because I had noise after we installed new brakes and rotor (but not squealing noise, more like something rubbing on something). The squealing noise came within a week after wheel hub and bearing install.
Do you still think that it's the brake pads not installed correctly?
Oct 23, 2019 at 10:39 PM
SCGRANTURISMO
  • 4,897 POSTS
When you changed the wheel hub did you pack the wheel bearing with grease?
Thanks,
Alex
2CarPros
Oct 24, 2019 at 12:45 AM
AMA
No, the bearing we bought came in sealed, looking similar to this:
https://www.carid.com/skf/wheel-bearing-mpn-fw201.html?singleid=2184026698&url=4275936
We bought brand new hub and bearing. We didn't pack it with grease. Were we supposed to put the grease on the outside of the bearing?
Thank you,
Oct 24, 2019 at 12:57 AM
SCGRANTURISMO
  • 4,897 POSTS
After doing some research, that bearing is packed with grease and sealed so that's not the issue. Did you get the brake shield installed back on correctly, or could it possibly have gotten reinstalled backwards?
Thanks,
Alex
2CarPros
Oct 24, 2019 at 1:15 AM
AMA
Hmm, unsure about shield. This afternoon, after work we are going to take a look at everything.
Any other ideas what can cause squealing? Since we will have things apart would be good to inspect all possible causes.
Oct 24, 2019 at 1:43 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
It could be a number of things. A rock could have gotten stuck in the brake caliper, the caliper could sticking closed, the brake shield. I did notice from the video, thank you for that by the way, that it sounds like your rotor may be out of round, so you may want to check the trueness of it while you are there. Please let us know what you find.
Thanks,
Alex
2CarPros
Oct 24, 2019 at 3:44 AM
AMA
It turned out to be a bend dust shield that was rubbing against the rotor. Luckily nothing major. But it was a good thing that was squealing like that because it forced us to take a wheel off and look at things. We noticed that in a process of changing wheel hub/bearing we must of punctured the cv axle boot because there was grease everywhere (luckily not on the brakes). We fixed one thing but screwed up something else. Oh well, you learn as you go.
But yeah, luckily the squealing was just a bend dust shield. I appreciate your time Alex answering my questions and addressing the issues. Thank you very much!
Oct 25, 2019 at 12:50 AM
  • 55,732 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Oct 28, 2019 at 5:27 AM
