Squealing and grinding noise
257,305 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
TRY2FIXITT
Noise is pretty loud when starting the car, has both periodically become louder and nearly stopped while driving. Thought the noise could have been the alternator belt was loose or needing to be replace, but it appears to be fine. And I hear the noise coming more from the passenger side of the car. I am just fixing what I can gal who hates getting in trouble when something goes wrong that I can be blamed on me. Any suggestions as to what possibly is the problem and maybe the cause of it as well is greatly appreciated and I thank you.
Nov 6, 2016 at 6:44 PM
HMAC300
  • 48,601 POSTS
remove the fan belt and start car and see if noise is still there if not then it may be a pulley or alternator noise. belt and tensioner should be replaced at 60,000 mile intervals.
Nov 6, 2016 at 10:48 PM
