Squealing engine
123,000 MILES • 2WD • AUTOMATIC
PIGG2123
Good morning,
I am concerned my dealer mechanic is unreliable. I went in a few months ago to get a few major check ups (90,000 and 105,000 - I have a replacement engine, so my car is 123,000 miles, but my engine is about 92,000).
They "forgot" to replace my belt during these major checkups, and I started hearing squealing, so I went back to get both the A/C and timing belts replaced.
It is a couple months later and the squealing when I start my car and accelerate is getting worse! I do not feel like I am getting the best service at my dealership, but I also don't want to blame anyone if it just so happens to be a new problem.
Can you please help me?
Apr 3, 2019 at 12:13 AM
Good morning,
Take a spray bottle of water and spray it on the belts and see if it goes away.
If it does, either the belt is loose or the belt is stretching already.
Apr 3, 2019 at 1:24 AM
MIKE H R
  • 3,094 POSTS
If the sound does not go away, you get from most auto stores a stethoscope like doctors {a couple of dollars} and use it by pinpointing whether it is a belt or pulley.
Apr 3, 2019 at 2:02 AM
The next step would be to remove the belt and spin each component listening for any abnormal noise.
Apr 3, 2019 at 2:03 AM
MIKE H R
  • 3,094 POSTS
that would work but found that some pulleys don't make a sound unless under pressure.
Apr 3, 2019 at 2:15 AM
Look for any play in the pulleys as well.
Apr 3, 2019 at 2:21 AM
MIKE H R
  • 3,094 POSTS
As ASEMASTER6371 recommends, also wiggle the each pulley to see if there is any play.
Apr 3, 2019 at 6:26 AM
PIGG2123
I just got both belts replaced a month ago. Do they not replace the pulleys in the process?
Thank you to you both. I appreciate the help!
Apr 7, 2019 at 12:28 AM
No, they will not unless there is any play or noise. Then they should notify you of the additional charges for replacing them.
Apr 7, 2019 at 12:33 AM
PIGG2123
Thank you, Roy. My Sunday project is underway.
Apr 7, 2019 at 12:34 AM
Got it.
You have a good day.
Apr 7, 2019 at 12:36 AM
